a avi TV Show or movie to DVD.
In general, your best bet is to use ImgBurn, not Nero, to burn a movie or TV Show to disk, if you want to play them in a standalone DVD player.
Are you saving the .avi file as data or do you want to play that on a DVD also? For playing the file in a standalone, assuming that your player will not play an .avi, I usually use DVD Flick for the conversion.
Both programs are free. Look to the left and click on tools. They are both there, fairly simple to use and well worth the download. -
Not a lot of information provided in your question, but, as a long-time user of Nero 7 (in spite of the guffaws such an admission usually elicits--always been happy with it), I'm wondering if you've tried NeroVision, which is part of Nero 7? It will take a wide variety of video files (including .avi) and convert them to a DVD-compatible format. It WILL re-encode everything, which will likely cost you some video quality. (Maybe that's the "why" of the aforementioned guffaws, or at least one of the reasons.)tcory sez: "Need help using Nero 7 writing a avi TV Show or movie to DVD."
Writing while angry?
By lordsmurf in forum Off topicReplies: 5Last Post: 28th Jun 2010, 18:46 -
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 16:38 -
Best writing media
By demonwarrior in forum MediaReplies: 4Last Post: 4th Sep 2007, 15:08 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 09:08 -
How do i change the default writing speed in Nero when using DVDshrink?
By wallacem4141 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 05:15
