Playing MKV files on my BlueRay standalone and some play at the correct 2:35 AR but others play full height with stretched image. Others won't play at all.
MKV supports display aspect ratio, but your blu ray player might not (probably doesn't)
Most blu ray players will only accept 1:1 square pixels and full frame sizes e.g. 1920x1080, 1280x720 . So a cropped MKV will usually not play unless you add borders
There can be many many reasons for a file not playing, including resolution, incompatible encoding settings, buffer settings
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Can You Change The AR Flags in an MKV file?
By wulf109 in forum Blu-ray RippingReplies: 5Last Post: 6th Jul 2011, 19:00 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45 -
-ss / -t flags?
By richlyon in forum ffmpegX general discussionReplies: 3Last Post: 9th Mar 2008, 08:58
