Hi,
I'm trying to get the text in the subtitles of an avi movie that also includes files with extensions IDX & SUB. The movie contains french text subtitles that I'm trying to extract. However when I use the "subtitle edit" application, I can only get it to use an english dictionary. That's not what I need. I want it to recognize french words. I even downloaded the french dictionary by using that same application, but that dictionary is not an option when I try to do OCR on those files.
How can I get this to work? Thanks a lot for your help with this issue.
Thanks,
Jose
You need both the open office spell check dictionary + the Tesseract dictionary (if you're going to use ocr via Tesseract).
The French Tesseract dictionary is available here: http://code.google.com/p/tesseract-ocr/downloads/detail?name=fra.traineddata.gz&can=2&q=
Unpack it to the "Tesseract\tessdata" sub-folder
Question about how to scan without image/OCR program
By jimdagys in forum ComputerReplies: 1Last Post: 9th Dec 2009, 23:33 -
French subtitle problem
By atyamamoto in forum ffmpegX general discussionReplies: 7Last Post: 15th May 2009, 12:31 -
Question about OCR that reads Chinese
By jimdagys in forum ComputerReplies: 1Last Post: 27th Nov 2008, 07:57 -
Adding English subtitle to french film?
By viruss3 in forum Authoring (DVD)Replies: 3Last Post: 23rd Apr 2008, 14:03 -
question about different OCR (optical character recogni) programs
By jimdagys in forum SubtitleReplies: 3Last Post: 19th Dec 2007, 18:31
