  1. In the most recent vcds i have burned when i try to play them on my vcd player the quality is either choppy or filled with weird green blocks. I know it is not the actualy vcd that i burned but rather my burner. I was wondering if anyone has had the same problem as me and was able to fix it somehow. Anyhelp is good help.
    Grim
  2. Try cleaning your discs..I sometimes have a problem with distortion in the images...cleaning the disch sometimes helps.. Wipe of grease en other dirt
  3. Also, try a different brand of CD-R, as well as different burning speeds.
