    Jul 2010
    United Sates Of America
    EDIT:I fixed it by using %% will show up as %
    I am currently using ffmpeg to extract all the frames from a video and it would work great except one problem.So I created a .bat file and then found out that in windows the % symbol means something special
    in command line so I tried changing:
    to:
    ffmpeg -i comet.avi "image-%d.jpeg"
    also when doing:
    echo "%"
    pause
    will show up as:
    Does anyone have a solution to this?
    thank you for your help if you do.
    Yep, use %%.
