I have a VCD I want to share in the net but I have no idea how to convert it back to anything.
Any ideas on how to?
I tried to see if TMPGE had anything, but I didn't find anything that would indicate so.
If you mean a VCD disc, explore the disc on your computer. You should find folders, one of which contains the mpeg1 file you can copy or play directly on the computer.
Funny, I looked in the folders and this are the folders I found:
a folder called CDI containing:
CDI_IMAG.RFT
CDI_TEXT.FNT
CDI_VCD.APP
CDI_VCD.CFG
a folder EXT with:
LOT_X.VCD
PSD_X.VCF
SCANDATA.DAT
MPEGAV:
AVSEQ01.DAT
and the last folder VCD:
ENTRIES.VCD
INFO.VCD
LOT.VCD
PSD.VCD
no Mpeg anywhere.... -
you can use virtualdub to convert to avi,divx and you open the avseq01.dat file because it is the video.
www.vcdhelp.com/avi2divx.htm
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
how to convert dvdrip avi's to vcd
By kissme1 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 9th Dec 2008, 15:19 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 16:51 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
