HI i apologize if this is a repost of somewhere, maybe im just not asking it the same way.
OK i want to be able to, for example take simpsons season 2 all 7 discs. i have ripped to the hard drive and have kept all the extras, menus etc, they are full rips. and want to make a super menu that will combine all the discs by acting like a dvd that is simpsons season 2 and have a menu to pick disc 1 through 7 then use the original disc menus to navigate each disk from there, like picking each episode etc.
ultimately id like to make a structure of simpsons dvd, thne a menu to pick season, then a menu to pick disc, then use the original menu for the rest..
im doing this cuz i want to be able to use media centers library to pick the show but the way it is now each disc shows up in the menu as its own movie and thats a lot when urr talkin about 7 discs per season times 20 seasons etc.
im hoping there is a freeware solution to this. i have dvd shrink and anydvd right now....
				Results 1 to 11 of 11
	There may be freeware solutions but for me I use ConvertXToDVD as it does exactly what you want. You can download a trial. SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	ok thanks im looking at it now, any chance u could give me a breif run through on how i might do that with the software? thanks again
	im just keeping them on my network hard drive so i can access them from windows media center as one dvd icon that i can then menu to each disc and episode from
	Can't you just put them in separate folders? Isn't there a folder navigation option?
	i dont want them in seperate folders, i want them in one. so that only one image shows up in media center library for the whole series
 There is a good help guide on line - just look under help menu. Basically tho' you just keep adding episodes as video files in the menu. Choose the type of menu you want.
 But basically you simply have to try all the options and explore for yourself, that's how I learnt to use the program.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	The only solution I have seen for (relatively) easily combining DVDs and keeping menus intact is DVD Remake Pro, but it may not give you something you really want to live with. You can merge up to four discs into one, which gives you a new menu at the top level to let you choose a disc. Once chosen, the original menu kicks in. If you wanted to merge 7 discs then you would have to merge four into one and call it disc 1, then merge the other three into a disc and call it disc 2, then merge the new disc 1 and disc 2 into your final disc. At this point you now have three levels of menu to navigate through to get to the episode you want to watch. Frankly, more hassle than it is worth. Read my blog here.
	ConvertXtoDVD inserts chapter points every (configurable) say 5 minutes in each title (episodes) on the disk but you can move them to suit. You could extract the timings of the original chapter timings of the original DVD's with chapterXtractor (google for URL) SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
  How to Cut & Merge mini 10 part mini series?By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41
  AVI files make DVD hugeBy dishwater63 in forum Authoring (DVD)Replies: 6Last Post: 13th Dec 2010, 20:09
  TV series to dvdBy frednufc in forum Newbie / General discussionsReplies: 6Last Post: 19th Nov 2010, 10:37
  900min in 1 DVD? Several hours/DVD? Multiple movies or tv-series/DVD?By edvashas in forum Video ConversionReplies: 17Last Post: 29th Sep 2009, 04:16
  DVD to FLV plus need to edit and file sizes are huge.By mickthetree in forum Newbie / General discussionsReplies: 9Last Post: 6th Dec 2008, 11:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
