Can someone tell me the best tool to use for putting a black bar across the bottom of the screen as I'd rather look at that and create a semi widescreen feel instead of the news scroll that's normally at the bottom when I record a TV show? I use Womble MPEG Video Wizard, Vido Re-do & Roxio Creator 2009. I've come across blur tools in these but would prefer the black bar, maybe I'm just overlooking it? Thanks in advance for help/replies.![]()
most of the time, the cropping tool will do this and retain the frame size
I use Border Control for VirtualDub -
What format is the source? What format do you want the final result? Lots of tools have cropping and masking functions.
VirtualDub.
One method I used to use, when it was just a simple scroller, was to crop the ticker and re-center the remaining footage. Basically it just pulled the image down a little, as there was enough info in the upper overscan to compensate. You couldn't even tell that the ticker had existed. I'd just correct bad scenes, too -- not the whole run of the video. Rarely did weather tickers ruin the entire recording.
These days, however, with 16:9, maps on screen, etc -- I don't think there's anything that can be done. There's just too much junk being put on screen now, waste of time to even record. (The people who try to "delogo" videos are stupid, as they just create annoying blobs worse than the original logo.)Last edited by lordsmurf; 28th Jun 2011 at 16:36.
Remove subtitle in black bar
By sltr1234 in forum SubtitleReplies: 4Last Post: 4th Dec 2010, 05:08 -
Black Bar problems with TMPGEnc
By ereiamjh in forum Video ConversionReplies: 5Last Post: 22nd Mar 2010, 10:32 -
how to remove black bar in video?
By yunakokimama in forum Video ConversionReplies: 3Last Post: 29th Oct 2008, 11:45 -
internet explorer : making a scroll bar
By mazinz in forum ComputerReplies: 4Last Post: 2nd Aug 2008, 05:14 -
Black bar problems
By mikeyspiky200 in forum DVD RippingReplies: 3Last Post: 1st Jan 2008, 11:45
