I just encoded a video with the correct resolution, but neglected to change the input DAR from 16:9 to 12:5, which the video should be. Is there a way I can fix this without re-encoding? The file is H264/MKV.
I searched around and found some answers, but I couldn't find a program that works for H264/MKV.
1. open the file with mkvmerge (mmg.exe; which is part of the mkvtoolnix package); drag&drop
2. select the V_MPEG4/ISO/AVC Stream than switch from gneral track-options to format specific options, specify the aspect ratio you want
3. Save the file under a new name (start muxing)
Assuming the player you use for playback properly supports mkv this should do the trick,..
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 19:12 -
Aspect Ratio Change
By VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 12:01 -
Have to change the aspect ratio - what is the right way??
By Weef in forum RestorationReplies: 25Last Post: 4th Mar 2009, 14:14 -
How to change aspect ratio?
By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 11:49 -
change aspect ratio
By zinc in forum Video ConversionReplies: 2Last Post: 23rd Jun 2007, 10:21
