Hi !
I try to capture video from my old VHS tapes. I use EasyCap.
Everything is OK, but there's one problem : a 10 seconds video is approximately 100MB.
I've tried encoding with different codecs, but the best is Huffyuv (v2.1.1). I use DScaler software, which is also good.
There was a problem while capturing(the video was black and white), but DScaler solved the problem quite easily.
It remains me to find a light codec, which will allow me to capture from VHS 2 hours without having a break, I beware of my hard disk.
I want good quality and small size of video.
What codec to use?
Depends on what you mean by "the best." If you want high-speed real-time capture compression and zero data loss, you're already using the best. A 2-hour VHS capture would be about 40 to 60 GB compressed, average. You can use VirtualDub to break that into smaller 4-GB chunks, recompress with Lagarith (lossless compressor, but a little too slow for capture), and burn the chunks to disc. For many, these are standard procedures.
You can also get fan-cooled external HDD enclosures and extra drives. Try Newegg or TigerDirect.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817173042Last edited by sanlyn; 20th Mar 2014 at 18:18.
For lossless and near lossless compression there's also UT Video Codec and the Fraps codec. Those are comparable in speed to HuffYUV and deliver a little more compression There's also a multithreaded version HuffYUV which is even faster than the old single threaded HuffYUV.
For more compression you can use a DV encoder (the source must be 720x480 29.97 fps or 720x576 25 fps). That will give you high quality (but not lossless compression) at about 13 GB/hr. And various MJPEG encoders where you can select the amount of compression. But the quality decreases as you compress more.
DV CODEC for VHS Capture?
By enbidia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 140Last Post: 24th Feb 2011, 20:11 -
Use a software codec when capturing with an ADVC300?
By timothyd_1975 in forum Capturing and VCRReplies: 22Last Post: 15th Jun 2009, 23:06 -
captured vhs to ffdshow codec video flashes
By gmanm1 in forum Capturing and VCRReplies: 1Last Post: 13th Dec 2008, 21:40 -
Best compression codec to use when capturing 720p video?
By Mysteriouskk in forum Capturing and VCRReplies: 3Last Post: 24th Nov 2007, 23:51 -
Which Codec is the Best for Capturing?
By rocknico100 in forum Newbie / General discussionsReplies: 4Last Post: 8th Aug 2007, 20:47
