  1. I've been trying to burn with Nero Burning Rom (www.ahead.de) recently, but after 3 cd's burnt, it seems to give me "Session Fixation Error", "Fixation error" after writing 5% to the cd..
    If there any settings I can change to avoid these errors ... ?
    Aug 2001
    Hull
    Are you using CD/RW disks, if so just get a good brand disk, like Philips Highspeed CD-RW74.
    I was using Memorex disks and i used to get Fixation error, but i do not get Fixation error with the Philips Highspeed CD-RW74, so all I can say is that the Memorex disks are shit.
    Shepo.
  3. Shepo: I'm using Delpi CD-R's (80min,700MB 16xmultispeed)
    Burner : "BurnProof" 12x/10x/32x
    I did manage to burn successfull cd's now, by reducing speed from 12x to 8x
    But I should be able to burn at 12x, the hdd is a western digital 100GB
    -ezcey-
