Results 1 to 12 of 12
    Jun 2011
    Australia
    I have a video file that has an original soundtrack and a voiceover soundtrack. I've already discovered from reading that it's pretty much impossible to remove the voice over unless they are separate tracks. So I was wondering seeing as the original audio is at a much lower sound volume/level is it possible to remove that OR remove the higher level voiceover?
    If so, are there any free programs that can do it?
    Thanks very much!
    USA
    I doubt it. It sounds good in theory, but both of your audio tracks are integrated with each other. Even if you are able to remove the high volume level data, the rest of it stays and would be just as loud as your desired data. Really no gain there.
    You could try the freeware audio editor Audacity . It has quite a few filters and you can easily expirement to see if you can get any improvements.
    Or someone here may have a better idea.
    Jun 2011
    Australia
    Thanks. Yeah... been playing around with Audacity for a little while now with no luck. I'm no expert though haha
    Jun 2011
    Australia
    I've seen programs that allow you to remove sound below a certain dB level. Can't you do this vice versa as well?
  5. Mod Neophyte redwudz's Avatar
    USA
    The usual problem with mixed audio tracks is that both share the same frequencies. Filtering works on both pretty much equally most times. But if you have low frequency or high frequency interference, you can sometimes 'notch' it out with the proper filters.
    But voices tend to be in about the same frequency range and very difficult to separate. And even if you could, you would also remove other parts of the audio track, such as music that contained the same frequencies.
    In the past, some Russian videos put the Russian translation over the English audio track and I don't believe anyone ever came up with a method to remove the overdub.
    Audacity is a good program, well worth learning how to use. I would suggest trying a short section of audio to experiment with, but I doubt you will get much improvement.
    Jun 2011
    Australia
    Dang... alright. Thanks for the help!
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    A number of separate issues here. But dealing with VO's
    Normally voice overs are mixed equally into the left and right channel so as to centre the voice so it may be possible to cancel it out by sum and difference ie Left minus Right. This will give you a mono rendition of everything else but without the voice - but this process is never perfect and there will be bleed or leakage. If the vo was mixed only to the left channel then you can't remove it other than turn off the left channel.
    Jul 2009
    Spain
    It will also of course remove any sound mixed into the centre of the original audio (ie before VO).
  9. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Yes of course that is implicit in doing a L minus R action.
    It would be useful if the OP posted a log of the file derived from MediaInfo. It might be an amp setting that can be modified or simply reducing the common signal, along with anything else in the centre channel but as the voice has been mixed at such a high level it would be masking any material located centre.
    Jun 2011
    Australia
    This what you looking for?
    General
    Count : 278
    Count of stream of this kind : 1
    Kind of stream : General
    Stream identifier : 0
    Inform : Matroska: 423 MiB, 1h 48mn
    Unique ID : 56161919633964462500258446601870461316
    Unique ID : 56161919633964462500258446601870461316 (0x2A40646C2EB0A2CAE9A287ED09F54984)
    Count of video streams : 1
    Count of audio streams : 1
    Video_Format_List : AVC
    Video_Format_WithHint_List : AVC
    Codecs Video : AVC
    Video_Language_List : English
    Audio_Format_List : AAC
    Audio_Format_WithHint_List : AAC
    Audio codecs : AAC LC
    Audio_Language_List : English
    Complete name : K:\crap\TV\Misc\Sport\Draft NBA 2011.mkv
    Folder name : K:\crap\TV\Misc\Sport
    File name : Draft NBA 2011
    File extension : mkv
    Format : Matroska
    Format : Matroska
    Format/Url : http://packs.matroska.org/
    Format/Extensions usually used : mkv mka mks
    Commercial name : Matroska
    Codec : Matroska
    Codec : Matroska
    Codec/Url : http://packs.matroska.org/
    Codec/Extensions usually used : mkv mka mks
    File size : 443233117
    File size : 423 MiB
    File size : 423 MiB
    File size : 423 MiB
    File size : 423 MiB
    File size : 422.7 MiB
    Duration : 6483640
    Duration : 1h 48mn
    Duration : 1h 48mn 3s 640ms
    Duration : 1h 48mn
    Duration : 01:48:03.640
    Overall bit rate : 546894
    Overall bit rate : 547 Kbps
    File creation date : UTC 2011-06-25 21:25:56.125
    File creation date (local) : 2011-06-26 05:25:56.125
    File last modification date : UTC 2011-06-25 21:50:03.296
    File last modification date (loc : 2011-06-26 05:50:03.296
    Writing application : DivXMKVMux 3.4.1.0004
    Writing library : libDivXMediaFormat 3.4.1.0004
    Video
    Count : 197
    Kind of stream : Video
    Inform : English, 480*360 (4:3), at 25.000 fps, AVC (PAL) (High@L4.0) (CABAC / 4 Ref Frames)
    Unique ID : 7670580600688494951
    Format : AVC
    Format/Url : http://developers.videolan.org/x264.html
    Commercial name : AVC
    Format profile : High@L4.0
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=4, N=50
    Internet media type : video/H264
    Codec ID : V_MPEG4/ISO/AVC
    Codec ID/Url : http://ffdshow-tryout.sourceforge.net/
    Codec : V_MPEG4/ISO/AVC
    Codec : AVC
    Codec/Family : AVC
    Codec/Info : Advanced Video Codec
    Codec/Url : http://ffdshow-tryout.sourceforge.net/
    Codec profile : High@L4.0
    Codec settings : CABAC / 4 Ref Frames
    Codec settings, CABAC : Yes
    Codec_Settings_RefFrames : 4
    Duration : 6483640
    Duration : 1h 48mn
    Duration : 1h 48mn
    Width : 480
    Width : 480 pixels
    Height : 360
    Height : 360 pixels
    Pixel aspect ratio : 1.000
    Display aspect ratio : 1.333
    Display aspect ratio : 4:3
    Frame rate : 25.000
    Frame rate : 25.000 fps
    Frame count : 162091
    Standard : PAL
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8
    Bit depth : 8 bits
    Scan type : Progressive
    Interlacement : PPF
    Interlacement : Progressive
    Delay : 0
    Delay : 00:00:00.000
    Delay, origin : Container
    Language : en
    Language : English
    Language : English
    Language : en
    Language : eng
    Language : en
    Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM
    Transfer characteristics : BT.470-6 System B, BT.470-6 System G
    Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601
    Audio
    Count : 158
    Kind of stream : Audio
    Inform : English, 48.0 KHz, 2 channels, AAC (LC)
    Unique ID : 16423127653980259545
    Format : AAC
    Commercial name : AAC
    Format profile : LC
    Codec ID : A_AAC
    Codec : AAC LC
    Codec : AAC LC
    Codec/Family : AAC
    Duration : 6483640
    Duration : 1h 48mn
    Duration : 1h 48mn
    Channel(s) : 2
    Channel(s) : 2 channels
    Channel positions : 2/0/0
    Sampling rate : 48000
    Sampling rate : 48.0 KHz
    Samples count : 311214720
    Compression mode : Lossy
    Delay : 0
    Delay relative to video : 0
    Video0 delay : 0
    Language : en
    Language : English
    Language : English
    Language : en
    Language : eng
    Language : en
  11. If you're lucky it could be a left/right split (original audio on one side, voice-over on the other). But you probably would have noticed that already.
    Jun 2011
    Australia
    Yeah. I already used Audacity to check the sound on left/right and it's the same.
