Hi again,
I realzed I posted my question in the wrong group ...
Do it again...
Hi there,
IMAV user working with FCP7, DVDSP, Toast10
After compressing a FCP project with Compressor and burning DVDSP with DVDSP, I realized that scenes containing objects or people in rapid movement where showing jerked images.
The slow motion scenes are fine.
I checked the following
settings for DVDSP burning: VBR two pass;
averageBit rate 4,0,
max rate 7,0
1) the self-contained QT that I started with is not showing this problem.
2) the m2v file obtained from compressor (I use preset setting for high quality compression) does not show this problem when I view it with MPEG streamclip
3) I tried to burn directly the QT file with Toast 10 …get same problem if not worse !.
settings for Toast
automatic re-encoding
average rate 4,0 Mbps
max bit rate 8,0 Mbps
MPEG-2
I guess my problem comes from the bit rate I used ?
I am now confused and I am not sure I understood the impact of the bit rate setting on the quality of the resulting DVD, and I believe that using a high bit rate in DVDSP might result in problems for some clients to play the DVD on their player ?
Could it be something else ?
could someone please give me advice ?
Many thanks in advance
Ivan
How are you viewing the actual DVD? Have you tried another player ?
Was the original content interlaced or progressive ?
Describe what you mean by "jerked image"
Do you mean forward-back-forward-back ? - this would suggest wrong field order
Or do you mean choppy as in strobe like motion ? - this would suggest you deinterlaced it somewhere
An average bitrate of 4Mb/s and max bitrate of 8Mb/s will have no issues in any DVD player in terms of playback problems
A Mac tool that can author .mpg to DVD folder for buring
By Sam0403 in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2012, 15:49 -
jerked images after burning DVD
By Ilovm in forum MacReplies: 3Last Post: 26th Jun 2011, 17:49 -
MS Movie Maker and buring DVD
By ccm in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2009, 17:49 -
Buring video to DVD player
By BVG in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2009, 14:58 -
converting m2ts for editing in Premiere Pro 1.5 and buring to DVD
By Trenidor in forum Authoring (DVD)Replies: 6Last Post: 3rd Jun 2008, 00:28
