I Have A DVD+RW It Used To Work But One Day When I Put It In The DVD Recorder It would Not Load So I Tried My Freinds DVD+RW The Same Make From The Same Pack and It Worked Can Someone Help Me![]()
Results 1 to 9 of 9
I never had much luck with RW discs in my recorder. They are supposed to be re-recordable dozens if not hundreds of times but I've had many that never lasted more than a few recordings. If this is an RW disc that has already been recorded to and you are trying to re-use it...try erasing it on a computer burner with something like DVDDecrypter. ImgBurn probably has the same exact erase feature but I have no RW discs to try.
If these are new discs you are trying....try a different brand of discs. RW discs are not known to be as good(quality) and normal -R or +R discs. -
Ive Recorded Over It About 20 or So Times and I Thought It May Last Longer Then That i Have a Feature On My Recorder That Lets Me Format It But When I Put It In Once It Didnt Work I Was Wondering If There Was A Way I Could Get It To Load Again
I Took A Look At The File Size And It Says Its 40 MB But The Disks Size Is 4. 7 GB
The number of times RW media can be re-used varies. I have had some RW discs that were probably re-used 20 times before failing, and others that failed after being used only a couple of times. Based on personal experience, if this DVD+RW disc has been used 20 times for recording, it could well be worn out.
If you need to save a recording from this disc, it may still be possible to do that using data recovery software on the PC. Otherwise, it is time to toss it in the trash.
Samsung tv wont read subtitles
By BigAl77 in forum SubtitleReplies: 15Last Post: 9th Sep 2016, 12:59 -
Datawrite disc wont read on pc and laptop
By lb77 in forum DVD RippingReplies: 3Last Post: 11th Nov 2009, 09:20 -
Disk wont read
By rheming3 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Dec 2008, 01:03 -
pioneer 115d wont read +rw disk
By dblake2 in forum DVD & Blu-ray WritersReplies: 5Last Post: 23rd May 2008, 03:47 -
@^DVD-Roms wont Read Dual Layer^@
By Varchasve in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2007, 19:13
