What is the best/easiest way to reduce the size of a DVD. I have several DVDs that I would like to backup but they are about 5-6GB after using IfoEdit. Is there a way to remove or cut cells from the original after ripping them???![]()
Using SmartRipper for example, rip only the movie. Second use "stream processing" strip out everything but 1 angle and one audio track. If you still are too big, you will have to do some encoding to get the size down.
Is there any way to reduce the size of subtitle fonts on an existing DVD?
By DeathStalker77 in forum SubtitleReplies: 4Last Post: 25th Jul 2011, 16:35 -
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 14:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 09:18 -
Need to reduce video size to less than 195MB
By EMK5810 in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2009, 01:22 -
Reduce size of video
By von_25 in forum Newbie / General discussionsReplies: 2Last Post: 27th Sep 2008, 07:25
