I have some .m2ts files from a Panasonic HD camcorder (AVCHD files). Due to the fat32 file system used by the SD card in the camcorder, the files are split at 4GB. Since the footage is of a live concert, I would like to join the m2ts files together without having to re-encode them. TSMuxer was able to join them, but the time code was off. It would only keep the time code of the first m2ts file even though the total file size was the sum of the two joined files.
In a nutshell, I want to join the m2ts files, create a chapter list once joined, then author a blu-ray. Here's what I've tried so far:
MulitAVCHD 4.1 Even when I set the split at 25000MiB, the files are still kept at their original size when I try to author a Blu-Ray
TS Muxer screws up the time code when joining
Tmpgenc Authoring Works will join them, but will re-encode to Mpeg2 which I do not want to do.
I'm at my wits end on how to do this properly.
A_L
I may have a solution. Try VideoReDo TV Suite 4 . .264 version. Request the Trial key that will unlock it to full function for a period of days. It has a joiner that works.
TVSuite/H264($100) can also author DVDs. Version 4 supports H264/AVC/MTS/M2TS/AVCHD/MP4 editing.
https://www.videohelp.com/tools/VideoReDo
http://www.videoredo.com/en/index.htm
Simply download V4, install it into its own folder, and go. If you want to remove the 15 minute limitation request a trial key either from help menu or the pop-up screen
Done. BTW I have been using it and its predecessor for may years. I love the interface and the utility QuickStream Fix solves many problems too.
Good LuckIf I'd known I was going to live this long, I'd have taken better care of myself. -
As I noted from above:
"Simply download V4, install it into its own folder, and go. If you want to remove the 15 minute limitation request a trial key either from help menu or the pop-up screen"
I love that program as it joins, it fixes stream errors that can cause sync errors, etc.
Glad to hear you have the problem sorted
problems splitting mkv files then playing on lg blu ray
By julie_152 in forum Video ConversionReplies: 6Last Post: 15th Jan 2013, 05:54 -
Problem authoring TS files to Blu-ray
By benbrown in forum Authoring (Blu-ray)Replies: 1Last Post: 7th Feb 2012, 17:19 -
HD camcorder to Blu Ray recorder?
By Lilygrace in forum Newbie / General discussionsReplies: 4Last Post: 16th Jul 2011, 03:22 -
Play files without authoring on my blu-ray player Sony BDP-S360
By vandaLo in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd May 2010, 23:50 -
Problem loading Blu Ray files into TMPGEnc Authoring Works 4
By DSguardian in forum Blu-ray RippingReplies: 0Last Post: 14th Apr 2010, 19:52
