Hey
How do you encode a DivX with TMPG Plus?
Is all have to do is to just load the d2v and wav files from DVD2AVI into TMPG and in the output box browse and save the file as whatever.avi?
TMPGEnc Plus cannot encode DivX only Mpeg 1 or 2 you might want to try VirtualDub, Flask, or DVDx to enocde to DivX
Yes, TMPGEnc will encode to divx, but not through the procedure you indicated.
Load your source.
Go to file > output to file > avi file.
Choose the proper video and audio codecs.
There is a cosmetic bug when searching for the button(s): they are to the far right across from where the video and audio checkmark boxes are located.
Mark -
hey i never knew tha all i kewn tha it can encode to avi not DivX becuase i could never see the Choose Codec button...dats great TMPGenc is the best multi purpuse encoder
Bloody hell LOL..... I wonder how many other people never knew that this existed
I didn't know you could do that either.
Speaking of that though, can en1 tell me what the BEST DVD -> DiVX guide is (and is there much difference w/using Codec 4.12 or 5?).
Thanks. -
I managed to correct the bug in TMPGEnc plus with Resource Hacker.
I made Video & Audio information labels smaller and moved
both settings buttons to the left.
Two Output frame as.... checkboxes at the bottom moved to the left as well.
Everything is now visible. Click http://members.lycos.co.uk/prishtinalia/tmpgenc.jpg to see.
PhArAoH -
can you send the patch u made to me and tell me how to apply it? Thanks
whoisyourdady3000@hotmail.com
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
Best settings voor TMPG Express MTS Files to Divx Avi
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 8th Mar 2008, 09:36 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 01:11
