I'm having a slight problem which I do not understand. I have about 200+ mkv's on my computer. Sometimes when I try to rename a file it takes minutes and my computer all of the sudden runs really slow. The other problem I have is sometimes I try to move them around into different folders and its says I can't because they're in use by explorer. Now it doesn't do it to all of them, but to some, and to the ones it does this to its consistently those same ones. Any ideas? Thank You.
BTW this happens on my Win 7 ultimate machine and Win 7 Home Edition.
** I put this in the wrong section (sorry) wanted to move to Newbie/general discussion
Last edited by xobituaryx; 25th Jun 2011 at 11:04. Reason: wrong section please move to newbie/general discussion
I'll move this to Newbie/General.
I've seen this problem a few times. Explorer is likely having a hard time reading the file, so it slows down. I've even had a few crash Explorer. Usually what I do is re-encode the MKV and that fixes it. Did you encode the problem MKVs the same way as the others?
You might try comparing a problem one to a known good one with MediaInfo and you might spot the differences.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
Problems streamin mkv's between computers using Win Media Player
By xobituaryx in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jan 2011, 05:19 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51
