I've got a movie that I'm trying to get into after effects.
MKV
Audio: A52 Audio (aka AC3)
Video: H264 - MPEG-4 AVC (part 10) (avc1)
1280x536
23.976215
So of course I try putting this into Media Encoder (to break it down so i don't have a 2 hour file in AE) and Encoder 5.5 gives me a File Import Error saying the file format is not supported.
So I tried Avidemux making clips in there. trying to make them mjpeg or a h264 avc in a AVI container instead and while the AVIs will get imported, encoder won't be able to find any frames, just black video.
Any idea what i'm doing wrong here? I thought 5.5 had support for MKVs
Yes I know, I was saying I thought CS5.5 had support for the MKV container, because i know it has support for AVC h.264 which is inside the MKV but as long as it's an MKV adobe won't let you import it.
I did the tsMuxer and that seemed to work, but i need to reinstall adobe because i just formated my system, so I'll post back with results, Heres to hoping this finally works
ok so MediaInfo says
BDAV: 4.64GB
Video stream: AVC
audio stream: AC-3
when I go to import it adobe says source compression not supported this time. So at least i got a container that plays nice with adobe but I guess there is something weird about that H.264 AVC that adobe doesn't like, Because I can't use media encoder what should I use for conversion? lots of recommend Super, but that's always just crashed and worked aweful for me.
Merging 2 mkvs into one
By leoficz in forum Video ConversionReplies: 8Last Post: 19th Apr 2012, 07:31 -
Hardsubbing MKVs
By Zepwich in forum SubtitleReplies: 5Last Post: 19th Aug 2011, 17:07 -
Blocky MKVs
By romanticwarrior in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Dec 2010, 16:06 -
Mkvs and LG BD390
By barkinglama in forum Blu-ray RippingReplies: 12Last Post: 30th Apr 2010, 08:45 -
Joining MKVs
By Amanaman in forum Newbie / General discussionsReplies: 1Last Post: 22nd Sep 2009, 12:27
