Hi,
I'm using a package to copy my VHS tapes to my computer. This package write the files as VOB.
These VOB files are sometimes large (8GB) and I'm trying to convert them in a small file size eg FLV using Avanti. Can anyone suggest what the best setting are to convert them with out losing any quality over the orginal VHS tape?
I'm wanting to endup with as small a file size as possible without loss of quality over the orginal VHS tape copy.
Avanti doesn't include many ready to use templates. They are meant as examples but I would try the "PS3 / h264 720x576 (extended tweaking)" template.
After loading it set the "Container" field to "flv". Set the DAR according to your source and adapt the bitrate a bit. It's by default set to 2050 kbps but you can lower it and do some test encoding to see what's acceptable.
Chris -
I've started converting my VHS collection to FLV - I'm using Avanti 0.59 with a sherpay
git-N-30172-g3c20c0e FFmpeg this works OK. However I'm getting noise and blockiness on some of the converted files. Can anyone suggest how I tweak this. I've tried other package like Movavi movie enhancer but the trial has run out and I'm unable to get any further with this. -
Look at the tools section https://www.videohelp.com/tools at "Video Encoders".
There are a lot of free converters to try. Can't give any advice on them but others may.
Converting Damaged VHS Tapes to Files on a HDD
By RhoXS in forum Capturing and VCRReplies: 5Last Post: 20th Feb 2010, 09:40 -
converting old VHS tapes to DVD
By ggg913 in forum Authoring (DVD)Replies: 3Last Post: 11th Sep 2009, 15:02 -
Converting old VHS-C and Hi-8 tapes to AVI files--HELP!
By molon labe in forum Newbie / General discussionsReplies: 10Last Post: 19th Dec 2008, 19:28 -
Converting VHS tapes to DVD
By mnewxcv in forum Capturing and VCRReplies: 42Last Post: 10th Dec 2008, 18:44 -
Converting VHS Tapes To DVD
By dbuser2 in forum Video ConversionReplies: 68Last Post: 23rd Jul 2008, 03:31
