    Oct 2006
    I just encoded a movie with Handbrake that, according to MediaInfo, has an aspect ratio of 2.35:1, but when I play it on my Roku it's showing up as 16:9 so the height isn't adjust properly.
    My video settings were Anamorphic : Loose, Modulus : 16
    It displays correctly on the PC but not on the Roku. Is there some way to fix this? Is there something I can change in the mp4 container that will make it display properly?
    I've got quite a few of these I don't want to have to re-encode.
  2. You mean the Roku is stretching the 2.35 picture vertically to make it 16:9?
    Oct 2006
    Yes - it still has some letterboxing at the top and the bottom, bet is stretched vertically. The Universal logo at the beginning of the movie looks like an egg and this isn't the Easter movie that came out this year (where the logo is supposed to look like an egg).
  4. What's the frame size of the video?
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Pictures help, even screen shots with digital camera.
    http://www.kiva.org/about
    Oct 2006
    Ok, here's some screen grabs/photos. The TV is an old one I've had since college so it's made for 4:3. The frame size is 865x368.
Name:	TV Shot 1.jpg
Name:	TV Shot 2.jpg
Name:	VLC Grab 1.jpg
Name:	VLC Grab 2.jpg
  7. What does MediaInfo say about the file? Frame width and height, display aspect ratio, etc.
    Oct 2006
    Here's what MediaInfo says. I even tried slapping it into a MKV container and specifying the ratio. I didn't try specifying the frame size though.
    General
    Complete name                    : True Grit (2010).mp4
    Format                           : MPEG-4
    Format profile                   : Base Media / Version 2
    Codec ID                         : mp42
    File size                        : 910 MiB
    Duration                         : 1h 50mn
    Overall bit rate                 : 1 154 Kbps
    Movie name                       : True Grit
    Recorded date                    : 2010
    Encoded date                     : UTC 2011-06-16 14:57:31
    Tagged date                      : UTC 2011-06-16 16:48:05
    Writing application              : HandBrake 0.9.5 2011010300
    Cover                            : Yes
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L3.0
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 4 frames
    Format settings, GOP             : M=1, N=49
    Codec ID                         : avc1
    Codec ID/Info                    : Advanced Video Coding
    Duration                         : 1h 50mn
    Bit rate mode                    : Variable
    Bit rate                         : 955 Kbps
    Width                            : 720 pixels
    Height                           : 368 pixels
    Display aspect ratio             : 2.35:1
    Original display aspect ratio    : 2.35:1
    Frame rate mode                  : Variable
    Frame rate                       : 23.976 fps
    Minimum frame rate               : 12.469 fps
    Maximum frame rate               : 59.920 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.150
    Stream size                      : 754 MiB (83%)
    Writing library                  : x264 core 112
    Encoding settings                : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Color primaries                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics         : BT.709-5, BT.1361
    Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format                           : AAC
    Format/Info                      : Advanced Audio Codec
    Format profile                   : LC
    Codec ID                         : 40
    Duration                         : 1h 50mn
    Bit rate                         : 192 Kbps
    Maximum bit rate                 : 318 Kbps
    Channel(s)                       : 2 channels
    Channel positions                : Front: L R
    Sampling rate                    : 48.0 KHz
    Compression mode                 : Lossy
    Stream size                      : 151 MiB (17%)
    Language                         : English
    Text
    Format                           : Apple text
    Codec ID                         : text
    Duration                         : 1h 50mn
    Bit rate mode                    : Constant
    Bit rate                         : 0
    Stream size                      : 140 Bytes (0%)
