Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
    Feb 2007
    Australia
    Originally Posted by electronicsguy View Post
    Originally Posted by stehow View Post
    If you want a quick way of batch processing all MKV files in a directory, setting the MKV title to the filename, then install mkvtoolnix and then create a batch script such as:
    echo ***** Starting MKVtitle *****
    for %%m in (*.mkv) do (
    echo Changing %%m Title to "%%~nm"
    "C:\Program Files (x86)\MKVToolNix\mkvpropedit" "%%m" -e info -s title="%%~nm"
    echo -----
    echo ***** Finished *****
    How to make this script apply to contents of subfolders as well?
  2. Originally Posted by nathan323 View Post
    echo -----
    I think the syntax mentioned here should work: DOS-FOR-LOOP
    for /r %%m in (*.mkv) do
    Jul 2007
    "C:\Program Files\MKVToolNix\mkvpropedit" "%%m" -e info -s title="%%~nm"
    echo -----
    This works wonderfully! But I would also love to have it find the total bitrate of both audio and video, and what parameters would I need to specify in the batch file to update those , so they will be accurate?
    I transcoded some 1080p files to 720p, and now the bitrate is shown from the original versions instead of what they really are now.
    I can't find any docs on either MKVToolNix or MKVPROPEDIT.
    Thanks.
