  1. Hello, i'm using clipbucket and when a user uplaod a video that have a bitrate bigger than 512 it fails to convert or doesn't convert correctly, can you help me solving this?
    I would like that my site convert all type of video that user upload like youtube!
    this is the log, thanks!
    Started on 2011-06-23 20:37:01 - 2011 Jun 23
    Checking File ....
    File : /home/livefeti/public_html/files/conversion_queue/1308854170a2d3b.wmv
    File Exists : Yes
    Preparing file...
    format : asf
    duration : 19.8
    bitrate : 5456
    video_width : 1440
    video_height : 1080
    video_wh_ratio : 1.33333333333
    video_codec : vc1
    video_rate : 25.0505050505
    video_bitrate : 5036
    video_color : N/A
    audio_codec : wmapro
    audio_bitrate : 387
    audio_rate : 48000
    audio_channels : 5.1
    path : /home/livefeti/public_html/files/conversion_queue/1308854170a2d3b.wmv
    Converting Video
    Conversion Command : /usr/local/bin/ffmpeg -i /home/livefeti/public_html/files/conversion_queue/1308854170a2d3b.wmv -f flv -vcodec libx264 -vpre medium -r 25 -s 640x480 -aspect 1.33333333333 -vf 'pad=0:0:0:0:black' -acodec libfaac -ab 128000 -ar 48000 -map_meta_data /home/livefeti/public_html/files/videos/1308854170a2d3b.flv:/home/livefeti/public_html/files/conversion_queue/1308854170a2d3b.wmv /home/livefeti/public_html/files/videos/1308854170a2d3b.flv 2> /home/livefeti/public_html/files/temp/13088542215c657.tmp
    Conversion Details
    FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
    built on Jun 5 2011 06:56:57 with gcc 4.1.2 20080704 (Red Hat 4.1.2-50)
    configuration: --prefix=/usr/local/cpffmpeg --enable-shared --enable-nonfree --enable-gpl --enable-pthreads --enable-libopencore-amrnb --enable-decoder=liba52 --enable-libopencore-amrwb --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --extra-cflags=-I/usr/local/cpffmpeg/include/ --extra-ldflags=-L/usr/local/cpffmpeg/lib --enable-version3
    libavutil 50.36. 0 / 50.36. 0
    libavcore 0.16. 1 / 0.16. 1
    libavcodec 52.108. 0 / 52.108. 0
    libavformat 52.93. 0 / 52.93. 0
    libavdevice 52. 2. 3 / 52. 2. 3
    libavfilter 1.74. 0 / 1.74. 0
    libswscale 0.12. 0 / 0.12. 0
    [asf @ 0x623b00] max_analyze_duration reached
    Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 25.00 (25/1)
    Input #0, asf, from '/home/livefeti/public_html/files/conversion_queue/1308854170a2d3b.wmv':
    Metadata:
    title : Min film 1
    artist :
    copyright : �
    comment :
    WMFSDKVersion : 11.0.6002.18049
    WMFSDKNeeded : 0.0.0.0000
    IsVBR : 0
    Duration: 00:00:19.88, start: 3.000000, bitrate: 5564 kb/s
    Stream #0.0(eng): Audio: wmapro, 48000 Hz, 5.1, flt, 384 kb/s
    Stream #0.1(eng): Video: vc1, yuv420p, 1440x1080, 5000 kb/s, PAR 4:3 DAR 16:9, 25 tbr, 1k tbn, 1k tbc
    [buffer @ 0x636220] w:1440 h:1080 pixfmt:yuv420p
    [scale @ 0x6412c0] w:1440 h:1080 fmt:yuv420p -> w:640 h:480 fmt:yuv420p flags:0xa0000004
    [pad @ 0x6415f0] w:640 h:480 -> w:640 h:480 x:0 y:0 color:0x108080FF[yuva]
    [libx264 @ 0x6364b0] using SAR=1/1
    [libx264 @ 0x6364b0] using cpu capabilities: none!
    [libx264 @ 0x6364b0] profile High, level 3.0
    [libx264 @ 0x6364b0] 264 - core 107 - H.264/MPEG-4 AVC codec - Copyleft 2003-2010 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=abr mbtree=1 bitrate=200 ratetol=1.0 qcomp=0.60 qpmin=10 qpmax=51 qpstep=4 ip_ratio=1.41 aq=1:1.00
    Output #0, flv, to '/home/livefeti/public_html/files/videos/1308854170a2d3b.flv':
    Metadata:
    title : Min film 1
    artist :
    copyright : �
    comment :
    IsVBR : 0
    encoder : Lavf52.93.0
    Stream #0.0(eng): Video: libx264, yuv420p, 640x480 [PAR 1:1 DAR 4:3], q=10-51, 200 kb/s, 1k tbn, 25 tbc
    Stream #0.1(eng): Audio: libfaac, 48000 Hz, 5.1, s16, 128 kb/s
    Stream mapping:
    Stream #0.1 -> #0.0
    Stream #0.0 -> #0.1
    Press [q] to stop encoding
    [vc1 @ 0x62c330] Interlaced WVC1 support is not implemented
    Error while decoding stream #0.1
    Multiple frames in a packet from stream 0
    frame= 0 fps= 0 q=0.0 size= 0kB time=7.06 bitrate= 0.0kbits/s
    frame= 0 fps= 0 q=0.0 size= 0kB time=14.06 bitrate= 0.0kbits/s
    frame= 0 fps= 0 q=-1.0 Lsize= 262kB time=19.78 bitrate= 108.4kbits/s
    video:0kB audio:246kB global headers:0kB muxing overhead 6.461260%
    final ratefactor: 37.54
    Merging existing onMetaData tag
    Video: 640x480 H.264
    Audio: 44100Hz 16bit stereo, codec ID 10 (AAC)
    Total: 49 video bytes (0.000000 kbps), 253611 audio bytes (0.000945 kbps), 2147483.647000 seconds long
    Final onMetaData tag contents: {
    IsVBR: 0
    WMFSDKNeeded: 0.0.0.0000
    WMFSDKVersion: 11.0.6002.18049
    artist:
    audiocodecid: 10.000000
    audiodatarate: 0.000945
    audiosamplerate: 44100.000000
    audiosamplesize: 16.000000
    audiosize: 253611.000000
    canSeekToEnd: true
    comment:
    copyright: �
    datasize: 268869.000000
    duration: 2147483.647000
    encoder: Lavf52.93.0
    filesize: 268062.000000
    framerate: 0.000001
    hasAudio: true
    hasCuePoints: false
    hasKeyframes: true
    hasMetadata: true
    hasVideo: true
    height: 480.000000
    keyframes: {
    filepositions: {
    1257.000000
    268849.000000
    times: {
    0.000000
    2147483.647000
    lasttimestamp: 2147483.647000
    metadatacreator: flvtool++ (Facebook, Motion project, dweatherford)
    metadatadate: Thu Jun 23 18:37:03 2011
    stereo: true
    title: Min film 1
    totalframes: 2.000000
    videocodecid: 7.000000
    videodatarate: 0.000000
    videosize: 49.000000
    width: 640.000000
    Unknown file details - Unable to get output video details using FFMPEG
    Time Took : 1.5904 seconds
    conversion_status : completed
    =========STARTING HD CONVERSION==============
    HD Video -- Conversion Command : /usr/local/bin/ffmpeg -i /home/livefeti/public_html/files/conversion_queue/1308854170a2d3b.wmv -r 25 -ar 48000 -s 960x720 -aspect 1.33333333333 -acodec libfaac -vcodec libx264 -vpre hq -crf 22 -threads 0 /home/livefeti/public_html/files/videos/1308854170a2d3b.mp4 2> /home/livefeti/public_html/files/temp/output.tmp
    Conversion Details
    Metadata:
    title : Min film 1
    artist :
    copyright : �
    comment :
    IsVBR : 0
    File for preset 'hq' not found
    =========ENDING HD CONVERSION==============
    =========STARTING HD META DATA REPARING==============
    HD Video -- Conversion Command : /usr/local/bin/MP4Box -inter 0.5 /home/livefeti/public_html/files/videos/1308854170a2d3b.mp4 -tmp /home/livefeti/public_html/files/temp 2> /home/livefeti/public_html/files/temp/mp4_output.tmp
    Conversion Details
    Metadata:
    title : Min film 1
    artist :
    copyright : �
    comment :
    IsVBR : 0
    =========ENDING HD META DATA REPARING==============
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    you could try the clipbucket help forum
    http://forums.clip-bucket.com/
