I'm working in FCP7 and I've got some .mts, .cr2 and .mp4 footage that I apparently need to find and download a codec for.
I found the website codecs.com and think I spotted a codec for the mp4 footage and maybe the cr2 footage, but most of my footage is the mts from a Panasonic camera. It seemed like the codecs I found might be for Windows based systems, though.
Any advice?
Results 1 to 9 of 9
FCP7 has no avchd(mts) support. See http://forums.macrumors.com/showthread.php?t=751978 for some solutions.
http://www.kiva.org/about -
Thanks, Baldrick. I'm going to check that out now.
The camera is a Panasonic AG HMC 70. Thanks for the reply edDV. -
Normal digital intermediates for Final Cut Pro are AIC or ProRes422.
You need to convert your AVCHD file to AIC digital intemediate.
http://www.shedworx.com/hd-information/avchd
http://prores-converter.com/2011/05/avchd-to-aic-converter-transcode-avchd-footage-pan...ic-mov-on-mac/Recommends: Kiva.org - Loans that change lives.
Thread moved to the mac forum where you can get more help.
Thx for the link, edDV. I downloaded the demo of Voltaic and am finally able to see the clips on my MacBook. Certainly a round-about way of doing things. Too bad Sony and Panasonic couldn't have reached some sort of agreement with FCP/Apple.
I see you're in NoCal - what do you do for a living? Are you an editor? -
It is mostly an Apple problem where they limit compressed HD editing to their own digital intermediate codecs.
FCP 7 should import AVCHD. I don't have that version so can't point to the methods. Both iMovie and Final Cut Express will import AVCHD and convert to AIC.
I mostly do project engineering work in the TV broadcast and post industry but I also run a small event/post production business on the side. I have been editing video since the 80s on multiple platforms.Recommends: Kiva.org - Loans that change lives.
A Newbie want to learn the codec pack system.
By beterhans in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2012, 10:36 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 15:10 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 22:47 -
Help! G2M3 codec (newbie post)
By bongvideos in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2010, 07:39 -
Newbie question about codecs and codec packs
By ExTF in forum Newbie / General discussionsReplies: 6Last Post: 12th Feb 2009, 14:45
