Hey guys,
So I put subtitles on my .avi movie using AVIAddXSub, and it works perfectly when I play it on my computer, but when I burned the movie onto a DVD using Windows DVD Maker, the subtitles are nowhere to be seen. I tried several different DVD players, and pressed the 'subtitles' button for each one to turn the subtitles on, but it says that there are no subtitles.
Is there anyway to make it work for Windows DVD Maker, or should I use a new program?
Also, I don't know if this has anything to do with anything, but when I was converting my movie to DVD, I forgot to change the aspect ratio to 16:9 from 4:3, so now I have to redo it anyways.
Thanks!
The alternative to conversion to DVD is get a DVD Player that supports divx. I have Philips 5990 that has UltraDivx support and also upconverts to HD if attached via HDMI cable. I use AviAddXSubs and just copy the .divx output to a "data DVD" made with Imgburn. Saves a lot of time. Plus you can often put 2 or 3 full length movies on a DVD5 instead of just 1.
edit: I guess the 5990 is obsolete now. But anyway, anything with UltraDivx support should do subs added with AviAddXSubs. All the Philips players I've had that played .divx/avi supported it and also my old OPPO player.Last edited by MilesAhead; 23rd Jun 2011 at 03:52.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 07:15 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 16:53 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10 -
help with converting AVI to DVD with subtitles
By Pariah in forum ffmpegX general discussionReplies: 13Last Post: 8th Mar 2008, 00:28
