Hi All,
I am based in UK and want to capture from my VHS player to AVI format on my PC. I am well familiar with what to do after that once I have .avi files. I have used Hauupauge USB devices before to capture direct to MPEG format, but usually are pretty poor quality transfers even with pristine source material.
PC world sell various devices, but most are primarily TV cards and seem to capture to MPEG. Does anyone have any advice on how I actually capture in .avi and what capture devices/cards are available to me?
I should say that I am running Windows 7 with an ATI graphics card. I have browsed the "how to" guides, but most seem to refer to older stuff and I am somewhat overwealmed by it all. Sorry for noob question. Many thanks in advance.
Cheers Jub
AVI is just a container format. It can contain anything from lossless uncompressed video, down to low bitrate XviD, with M-JPEG and DV-AVI being common and somewhere in the middle.
So, which do you want? What do you intend to do with it?
Cheers,
David. -
Thanks David, I am not entirely sure. I have used avi with the XviD codec before that people have supplied to me (according to GSPOT), but in terms of my own captures, whatever is going to be a sensible balance really as the source material will invariably not be of top quality.
I will store the avi onto a hard drive for backup purposes, and also convert to MPEG format using Media Converters avi to Mpeg software for use in DVD LAB PRO 2 afterwards which seems to work very well for me. -
HuffYUV (yuy2 color format) and audio uncompress
with VHS you'll have to filter
you can try every alternetive you want ,
but you will fold back to that option eventually
suggested reading : http://www.doom9.org/index.html?/capture/start.htmlLast edited by smartel; 22nd Jun 2011 at 10:47.
For best results you need to use a line time base corrector. That usually means an S-VHS deck. You can also get away with something like a Panasonic ES-15 DVD recorder in pass-through mode.
https://forum.videohelp.com/threads/306272-Computer-video-capture-vs-vcr-to-dvd-combo?p...=1#post1882662
https://forum.videohelp.com/threads/319420-Who-uses-a-DVD-recorder-as-a-line-TBC-and-wh...=1#post1981333
Cleaning up the horizontal time base is essential to good recordings and it can't be done in software.Last edited by jagabo; 22nd Jun 2011 at 12:28.
ok... thanks for replies. I had a look at that Doom9 guide, but its too complex for me to start with. I guess I just need advice on what card might work with what capture software under Windows 7. I get it that the software has to use a codec, but that bit doesn't seem too bad. I know I'm simplifying, but if the audio is in sync, then I'm pretty happy, the source VHS quality won't be great anyway so no need for Rolls Royce solution.
Jag, will check those links today
Cheers Jub
AVI mono movie too big to burn on to single layer DVD-other options?
By nzdreamer55 in forum Authoring (DVD)Replies: 7Last Post: 29th Apr 2011, 14:45 -
avi capturing
By so in forum Newbie / General discussionsReplies: 10Last Post: 11th Jun 2010, 15:46 -
480p 16x9 capturing WITH 5.1 fiber optic input options?
By yoda313 in forum Capturing and VCRReplies: 39Last Post: 2nd Dec 2008, 16:15 -
capturing avi frames
By Willy5157 in forum Video ConversionReplies: 2Last Post: 8th Jul 2008, 19:22 -
Capturing Analog Video: Device Options (Survey/Questions)
By SHVideo in forum Capturing and VCRReplies: 6Last Post: 12th May 2007, 21:19
