i have tons of movie at .mkv at resolution 720p, im need some program conversion to insert on my ipad
and i have some trouble regarding resolution, when im using handbrake is converted to resolution 1024x568. and question is which proper resolution on ipad for 720p ??.
with these ( 1024x568 ) resolution the video seems to small .. or i have to cropping blackbar ?? how proper resolution for better view ??
Don't believe the Apple hype. They may play 720p files but they don't display 16:9 as 720p.
The iPad screen is 1024x768 which is 4:3 aspect ratio.
16:9 will display as 1024x576 with letterbox.
A standard 2.35 to1 movie will display on the iPad as 1024x435 with larger letterbox. This is near PAL DVD resolution not very HD.
Follow the Handbrake template.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
How to play native avchd files on ipad2
By merovingio in forum Video ConversionReplies: 2Last Post: 5th Oct 2011, 17:55 -
Convert AVCHD (MTS) to IPAD2
By merovingio in forum Video ConversionReplies: 1Last Post: 3rd Oct 2011, 05:50 -
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 04:42 -
By Krissu in forum Video ConversionReplies: 1Last Post: 2nd Mar 2011, 17:49 -
reclock not compatible with .mkv files?
By THX-UltraII in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2008, 07:57
