Hi guys,
As the title says; I need a solution to transcode a big batch of files, but i also need to keep the folder structure of the source the same as destination i.e.
Input
c:\input\folder name\folder\file1.flv
c:\input\folder name\folder\file2.flv
c:\input\folder name\folder\file3.flv
etc
Output
c:\output\folder name\folder\file1.f4v
c:\output\folder name\folder\file2.f4v
c:\output\folder name\folder\file3.f4v
etc
I know Carbon Coder can do this, but at the moment it doesn't except FLV files.
Anyone got any solutions for this?
Thanks!
I found the following and SLIGHTLY modified it to suit my needs. But doesn't really do anything else apart from opening up the script - Where am i going wrong? This is using VLC to transcode out.
Code:FOR /R %%G IN (*.flv) DO (CALL :SUB_VLC "%%G") FOR /R %%G IN (*.flv.f4v) DO (CALL :SUB_RENAME "%%G") GOTO :eof :SUB_VLC SET _firstbit=%1 SET _qt=" CALL SET _newnm=%%_firstbit:%_qt%=%% SET _commanm=%_newnm:,=_COMMA_% REM echo %_commanm% CALL "C:\Program Files (x86)\VideoLAN\VLC\vlc" -I dummy -vvv %1 --sout=#transcode{vcodec=h264, vb=400, acodec=mpga, ab=64,"channels=1",samplerate="44100"}:standard{access="file",mux="mpeg1",dst="%_commanm%.f4v"} vlc:quit GOTO :eof :SUB_RENAME SET _origfnm=%1 SET _endbit=%_origfnm:*.flv=% CALL SET _newfilenm=%%_origfnm:.flv%_endbit%=.f4v%% SET _newfilenm=%_newfilenm:_COMMA_=,% COPY %1 %_newfilenm% DEL %1 GOTO :eof :eof
f4v needs flv for audio... how to convert??
By nanrector in forum Video ConversionReplies: 16Last Post: 7th Apr 2012, 10:56 -
Trying to encode the video file from f4v to mp4 for mobile devices
By timurka in forum Portable VideoReplies: 1Last Post: 26th Jan 2012, 20:17 -
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 17:21 -
Does changing file extension from .f4v to .flv have any negative effects?
By huntaaar in forum Video ConversionReplies: 5Last Post: 2nd Sep 2010, 11:49 -
open source program for converting .avi and/or mpeg-2 to .f4v
By lapchumic in forum Video ConversionReplies: 2Last Post: 9th Jun 2008, 12:10
