Im try to convert FLV to AVI using AVS Video Converter
Its take 10 hours to complete 1 video and i have 100 video to convert so its take very long time to finish
My Laptop is Toshiba Satellite L745 i5-2410
Here video details and conversion detailsCode:CPU Speed : i5-2410M 2.3GHz 3MB L3 Graphics Type : Nvidia GT540 1GB DDR3 Memory : 4GB DDR3 RAM Operating System : Microsoft Windows 7 Home Premium (32bit)
Anyone know the problem ? Or maybe can suggest me any other converter that can work faster with output size ~350MB-400MB , also can resize and reduce bitrate like AVS Video Converter do with my setting above
Results 1 to 10 of 10
Try Freemake video converter, you can resize and adjust the bitrate.
So you think this is my system problem or software issues that not really compatible ?
Probably software. Or the video source might be corrupt, like it says 90frames/second...
Hurm...running for 15 minutes and conversion progress still 0%, using Freemake video converter
Complete name : D:\01.flv Format : Flash Video File size : 696 MiB Duration : 45mn 38s Overall bit rate : 2 133 Kbps _code : NetStream.Data.Start / NetStream.Play.Complete _level : status _duration : 288.000 _bytes : 80588125.000 Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=4, N=52 Codec ID : 7 Duration : 45mn 38s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Variable Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM Transfer characteristics : BT.470-6 System B, BT.470-6 System G Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601 Audio Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 10 Duration : 45mn 38s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy
I think the "Frame rate mode : Variable" cause the problems.
You could try avidemux, open flv, under video choose xvid, click configure to adjust bitrate, under audio choose mp3, save as a avi. But I guess it will also fail or you will get sync problem. -
Oh..thank you so much..maybe i should try to convert from RAW file...thansk again
Best quality flv to avi conversion
By Johnbil in forum Video ConversionReplies: 4Last Post: 22nd Mar 2012, 19:05 -
Having trouble with a conversion (mp4 / avi / mov / flv)
By loxley in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 11:17 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
By dread in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 14:38 -
Strange colour on AVI to FLV conversion
By Ian J Richards in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:05
