  1. Following formulas hold good for MPG / MPEG stream video size and bit rate calculations
    http://www.freeimagehosting.net/uploads/54d6509b88.jpg
    MPG / MPEG VIDEO SIZE AND BITRATE CALCULATION
    If you have more than one audio, sum up all audio stream bit rates.
    Hope someone can make nice GUI based calculator using above formula to calculate either Video Size or Video Bitrate with multiple audio stream bit rates.
    USA
    If you are familiar with MS Excel or other types of spreadsheet software, you could create one yourself. But I just use the VideoHelp Bitrate calculator in advanced mode and you can plug in numbers in about any box and the others will reflect the changes.
  3. Originally Posted by redwudz View Post
    If you are familiar with MS Excel or other types of spreadsheet software, you could create one yourself....
    that's exactly what i do!
