Hey guys, when I play a video in Windows Media Player or another program or when I play dvd with Powerdvd there seems to be quality loss. The image looks "smooth" and "doughy" and not as detailed as it should be. However, in VLC player it's fine. Hope this makes sense.
I was wondering if someone could help me with this? Is it some sort of codec problem?
Thanks.
Sounds like a hardware acceleration/video overlay issue. Try start two windows media player and play same material. Do you see any difference? One will use video overlay and the other one not.
Windows Media Player is such a terrible program that I really wonder if it wasn't deliberately designed to be as craptacular as possible. Honestly, you would do well to just stop using it forever and not worry about making it "better", which I don't think is even possible. It's bloated with DRM "goodness" and sometimes just refuses to play videos at all that it is theoretically supposed to support. Really, stop using it.
There's some kind of deinterlace setting on PowerDVD that might cause problems. You should check and see what you've got that set to and try a different setting. "Progressive" has been reported to work well for a lot of people.
VLC uses its own codecs and has more sensible default settings than PowerDVD so that's probably why it looks better. It may have a better deinterlace option than PowerDVD does on interlaced video. Or it could be that it's smart enough to not deinterlace progressive video and PowerDVD is stupid enough to try that.
Can't open MKV file ripped from DVD - Plays in VLC but not in edit programs
By dsunbury in forum DVD RippingReplies: 3Last Post: 7th Apr 2011, 05:21 -
clearer VLC video quality like WMP help please
By xbullet in forum Newbie / General discussionsReplies: 19Last Post: 1st Dec 2010, 13:34 -
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 14:56 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 11:01 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 01:03
