we are searching for a solution to this problem:
we have a low-end-cpu and want to record signals from 2-4 video cameras (low-res: 320x200). a hardware device should make a single video channel of these signals so that the CPU only receives one video that can be read via direct-x.
do you know any products for such a use case?
e.g. the "EasyCap Model 002 - 4 Channel USB 2.0 DVR Video Audio CCTV Capture Adapter" is almost what we want - the only problem is, that you can only view all channels within their own software - over direct-x you always get only one of the 4 video channels.
regards
	You can probably build a filter graph with Graph Studio and open that in some recording software.
	Oh, I left out a part: You build four filter graphs to capture from each device. Then use an Avisynth script to open each of those graphs (DirectshowSource) and composite the four images into one (StackHorizontal, StackVertical). You then open that AviSynth script in whatever software you want.
	I think this does what you want:
 http://www.amazon.com/Datavideo-Digital-Switcher-Composite-S-Video/dp/B0018D5BFC
 The cameras must put out standard video signals.
  converting mpeg into multi channel audioBy markdueck in forum Newbie / General discussionsReplies: 0Last Post: 5th Jun 2011, 17:35
  I Need a multi channel capture device, what should I buyBy flyrplnz in forum Capturing and VCRReplies: 0Last Post: 3rd Mar 2010, 22:39
  SW for multi-channel capturingBy Rakrul in forum Capturing and VCRReplies: 8Last Post: 24th Apr 2009, 12:42
  Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35
  Properly encoding multi-channel AC-3 to multi-channel AACBy PuzZLeR in forum AudioReplies: 1Last Post: 15th Nov 2007, 14:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
