I just wonder if there is diffrences in playback quality between play a MKV (x.264) from my PC to my TV and if i take for an example a WD Media Player with the picture processor Sigma EM8655 inside.
Can i tell difference in the picture quality?
Does the graphic card in my PC (Asus EAH2400) affect the picture quality as well or is it so little that it's not worth upgrading just for that?
It depends on how the connection is set up from your PC to TV. Some HDTVs only accept VGA input from computers and that should be a lower quality picture than you would get from a WD player. Can you actually tell any difference though? Hard to say. If your TV accepts DVI or HDMI input from a PC then I would not expect you to notice any difference and feel that getting a better graphics card would not result in any quality difference you could see.
ATI graphics cards have AVIVO functions that can perform a lot of filtering. Nvidia has similar functionality. Whether or not your video needs that is another question.
http://www.anandtech.com/show/4380/discrete-htpc-gpus-shootout
http://www.anandtech.com/show/4263/amds-radeon-hd-6450-uvd3-meets-htpc
WDTV graphics processing is primitive in comparison.Last edited by jagabo; 21st Jun 2011 at 10:58.
The TV itself may do its own sharpening and possible filtering of the image on top of it, which makes me question whether paying for a better video card to do the job is really even necessary.
Deblocking and deringing is useful for standard definition DVD and Divx/Xvid. Sharpening (the way it's implemented in a playback scenario) is almost never necessary. Most of the telecine patterns that HQV test for are rarely ever seen. The color and contrast is already correct for any professional Blu-ray or DVD source. And noise reduction is almost always a detriment to Blu-ray or DVD sources.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Whats the difference between these 2 MKV files?
By dave in or in forum Video ConversionReplies: 2Last Post: 11th Aug 2011, 16:44 -
quality difference for multiple reincodes
By resloan in forum Newbie / General discussionsReplies: 14Last Post: 30th Mar 2010, 22:31 -
Best quality option to convert 1080p mkv to 720p mkv
By carlmart in forum Video ConversionReplies: 5Last Post: 14th Mar 2010, 08:17 -
Will there be a difference in output quality?
By ingeborgdot in forum EditingReplies: 55Last Post: 21st Sep 2008, 19:41
