I normally use my projector, i use a vga male to vga male cable i attach a vga female to dvi male converter, works great. This time i used another projector that has hdmi i had a hdmi male to hdmi male cable then i bought a hdmi female to dvi male converter to plug that in my mac. I was getting signal but the screen wasn't very clear i had swirls of color, i adjusted some videos settings on my laptop, didin't work. Could this be because of the converter,my mac or the projector?
thanks a lot!
You mean projector is VGA and computer end is DVI-I? If so this is all analog VGA.
Umm, seems all DVI-D but unclear. A different digital technology.
OK, now we know you have some kind of Mac laptop. Mac and projector need configuration.
Suggest you make an appointment and haul it all down to the genius bar.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Great thanks for the help, im getting signal thats for sure, like i said the signal is unclear..seems like a problem with the colors for a split second the colors are clear and everything seems to work.
Can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA?
By vinny88 in forum Authoring (DVD)Replies: 4Last Post: 14th Oct 2011, 08:31 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
HD 720 sanyo: A way to downstep from hdmi, vga or dvi?
By reallyreallyconfused in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2010, 22:50 -
Connect VGA/DVI/HDMI source to Component HDTV
By jstewar9 in forum Media Center PC / MediaCentersReplies: 0Last Post: 13th Jan 2010, 15:11 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 20:37
