My M2TS files have no audio when played in either Windows Media Player 10 or Windows Media Center 7. I need Media Center because this is a HTPC. The audio format on these M2TS files is PCM.
I also have some M2TS files that have audio format AC-3 that play fine in Windows Media Center 7.
Checking the various forums for Windows7, there seems to be a problem with PCM audio. I did not have this problem with Vista, it just appeared after I upgraded to W7. I can also replicate it on any machine running W7.
Is there a way to take an M2TS file and convert just the audio portion of it to AC-3 or MP3 or any other format that Windows can handle. I have tried my converters to fully convert to avi, mpeg, mp4 and there always seems to be a degradation in the video part of it even though it does fix the audio part.
Any recommendation would be highly appreciated.
Closed Thread
Continue in your first similar thread. https://forum.videohelp.com/threads/335597-No-audio-playing-M2TS-files-with-Windows-Med...54#post2084354
Possible to convert a 5.1CH 4608kbps PCM audio track to a 1536kbps 5.1 DTS?
By fluxcapacitormb in forum AudioReplies: 4Last Post: 20th May 2010, 15:46 -
convert 2 audio track xvid file to ipod 3g
By felix in forum Video ConversionReplies: 1Last Post: 8th Oct 2008, 15:45 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 22:07 -
M2TS & DTS Audio Track
By GeeForce11 in forum Blu-ray RippingReplies: 25Last Post: 14th Jul 2008, 21:31 -
How do I convert .ogm file to .avi and keep a certain audio track?
By Moldiver in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 09:43
