Hi
A friend gave me an older Yamaha TV [TxP2734] that has video component in - should I look at getting an hdmi to component cable set in order to play from my HD mediaplayer [Patriot Box - HDMI and Composite Out] or will I just get the same quality using rca composite cables
TIA
wiseant
That's a standard def TV right? HDMI to component will get you a slightly better picture. But it's probably not worth it.
http://www.amazon.com/HDMI-RCA-component-AV-Converter/dp/B002WBOQPU/
Save your money for a new TV. -
Hi jagabo
Yeah, it just SD - I did try my DVDPlayer with component - it worked - hard to tell if it was better than composite or s-video
My mediaplayer just has hdmi and composite - I was looking at http://www.dinodirect.com/HDMI-to-Component-Video-with-Stereo-Audio-AV-Cable-1M.html?c...r=CAD&AFFID=67 -
That cable won't work unless your player supports component at the HDMI port -- that's very uncommon. Check your player manual. Here's a similar cable at Amazon:
http://www.amazon.com/HDMI-RCA-component-AV-Converter/dp/B002WBOQPU/ref=pd_cp_e_1
Notice all the 1 star reviews? My guess is most of the reviews at dinodirect are fake.Last edited by jagabo; 20th Jun 2011 at 07:48.
HDMI vs. Component for 1080i?
By Xylob the Destroyer in forum DVB / IPTVReplies: 12Last Post: 7th May 2010, 14:29 -
S-Video to HDMI or Component ?
By Kweldood in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st May 2009, 17:05 -
component or hdmi
By devdev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 23rd Jul 2008, 19:55 -
HDMI vs Component.....
By snadge in forum DVB / IPTVReplies: 6Last Post: 27th Feb 2008, 18:02 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25
