I've read through many posts looking for help but haven't found a response that works. My .mts files won't play in MPC, MPCHC and Splash (no sound, no picture); vlc (sound, picture, but pixelated); the KMPlayer and wmp (sound, picture but choppy). h.264 is installed. But they will play fine in Cyberlink PowerDVD 9.0. I have ffdshow and haali splitter installed; DVXA is supported. PowerDVD doesn't have many optional settings including codec settings so I can't see what it's using but de-interlacing mode is set to none.
Any thoughts?
Computer specs:
2 years old
laptop
2.40 gigahertz Intel Core2 Duo P8600
3072 kilobyte secondary memory cache
3536 Megabytes Installed Memory
160.04 Gigabytes Usable Hard Drive Capacity
On device manager under display: microsoft sms mirror driver and Intel chipset.
Results 1 to 13 of 13
Here's the MediaInfo info:
General
Complete name : C:\Documents and Settings\brownjim\My Documents\My Pictures2\ww ii 2011\video wwii\00408.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 57.0 MiB
Duration : 29s 430ms
Overall bit rate : 16.2 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : 27
Duration : 29s 463ms
Bit rate mode : Variable
Bit rate : 15.3 Mbps
Maximum bit rate : 16.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.246
Stream size : 53.7 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 29s 536ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -67ms
Stream size : 923 KiB (2%) -
I updated the K-Lite codec pack and there are some changes. MPC, MPCHC and VLC have sound but are choppy. Splash has no sound and no picture. WMP: sound but choppy picture. Cyberlink: works fine. When I updated K-Lite it gave me a message at one point asking if I wanted to install VobSub since I already had Cyberlink H.264 installed. I say no.
I used the default installation with the exception of the Cyberlink H.264. What do you mean by "lots of stuff"?
I have only mpchc and haali media splitter and all mts works fine. No packs.
When you install k-lite, there is an option to use different type's of installation: default, only playback, lot's of stuff, everything(not recomended).. e.t.c.
Have you tried "DAPlayer" from digiarty'com ??
I know i have tried it some time ago, and it had good deinterlacing for the same type of video as your's, but i like mpchc more, it has dxva support, and i like the deinterlacing from it.
This is an example of my mts, its 90% as your's.
General
Complete name : E:\SONY\VIDEO\AVCHD\BDMV\STREAM\00000.MTS
Format : BDAV
File size : 333 MiB
Duration : 2mn 4s
Overall bit rate : 22.4 Mbps
Maximum Overall bit rate : 24.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format settings, GOP : M=1, N=26
Codec ID : 27
Duration : 2mn 4s
Bit rate : 21.3 Mbps
Maximum bit rate : 22.0 Mbps
Frame rate : 25.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.410
Stream size : 315 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Codec ID : 129
Duration : 2mn 4s
Bit rate : 256 Kbps
Bit depth : 16 bits
Delay relative to video : -80ms
Stream size : 3.79 MiB (1%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 2mn 3s
Delay relative to video : -80ms -
Uninstall k-lite and install ffdshow and haali media splitter then try.
Uninstalled k-lite then installed ffdshow and haali media splitter. Same result. I should add that the results are the same whether playing from the camcorder or from the hard disk.
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 21:21 -
Video to MTS Converter, Not MTS to other videos
By dzsoul in forum Video ConversionReplies: 3Last Post: 18th Apr 2011, 10:16 -
Cyberlink PowerDVD Crashing PC on Fast Forward
By apostrophe in forum Software PlayingReplies: 2Last Post: 6th May 2010, 14:48 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 06:15 -
Cyberlink Director
By micromack in forum Authoring (DVD)Replies: 1Last Post: 1st Jun 2007, 16:38
