Hello,
I have been evaluating this VCR. Picture is GREAT! It seems though, that component RGB output is only available if you use a W-VHS tape? So the component output will not function if playing back a normal non "W-VHS" tape.
Conversely, a W-VHS tape seems to ONLY playback on Component output. Is this standard functionality for a SR-W7U?
Does anyone have any additional information on settings/etc that will allow the component RGB output to work with a VHS tape?
Thanks for your help.
Yes, both of your observations are true. You can't play a WVHS tape over the analog input on this deck, nor can you feed a VHS or SVHS tape signal over anything but the composite and S-VIDEO connections.
JVC SR-W7U questions
By Cingular in forum Capturing and VCRReplies: 3Last Post: 15th May 2011, 01:56 -
Is there a drop-dead date for high def output over component cables?
By yoda313 in forum Capturing and VCRReplies: 12Last Post: 27th Jun 2009, 00:42 -
sony hdr sr12 output to klv32s200a via component
By tomhanks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 29th Dec 2008, 18:01 -
vdeo bandwidth on component output.
By jmann in forum Newbie / General discussionsReplies: 2Last Post: 27th Sep 2008, 12:02 -
ATI X1900 GT Component Output
By DVDDave in forum ComputerReplies: 2Last Post: 13th Feb 2008, 17:41
