I've been making videos for youtube (mpeg II 640 X 360 29 fps) but little 3 minute videos are 100-120 megabytes and I am running out of storage space for my backups! I have seen hourlong TV episodes at 700 megabytes so I know there must be better compression methods for only 3 minutes of video.
1) What is the best format/codec?
2) Does anyone know how I can change the codec in Sony Vegas, or if not do I need another program like Pinnacle? Do I need to make the videos from scratch and then rerender them in another?
Any advice would be appreciated,
Steve
Results 1 to 9 of 9
Thanks. I did a test with it and the results were ok but not as good as mpeg-2. Do you have any advice on settings for h264 when encoding/rendering?
--Steve -
That's why I use the X264vfw codec with VirtualDub to create my YouTube uploads. Just leave it at the default compression(26.0)....and I resize(under VIDEO - FILTERS) the video down (to 75%) and tick the multiples of 16 box (you may only need multiples of 4 though....can't remember). Of course you can leave it full size and change the compression to higher quality....the choice is yours....but smaller file size means less quality....no way around it....but H264 is the best compromise.
New format/codec: Need to learn how to utilize it. Please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2011, 15:49 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Best Video Format/Codec For Small Size, Yet Low Loss In Quality?
By kiwisoup in forum Video ConversionReplies: 13Last Post: 27th Jul 2010, 10:01 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
What Program allows me to View Video Format/Codec etc..
By YuJay in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 09:19
