I have a HP DV7 laptop that does not have a firewire or PC Card Slot.Does anyone have any suggestion for how I can capture from my mini dv camecorder? It does have USB and ESATA. All ideas would be appreciated.
Thanks,
Chris
What's the model and brand of your camcorder? Most times, a USB connection is just for lower quality web video. I'm guessing you don't have a PCMCIA slot. If not, you may be able to find a FireWire to USB adapter, but I've no idea how well those might work. Others here might.
Newer laptops seem to have done away with FireWire connections.
Be aware that DV is about 13GB per hour of video, so it's not that well suited to laptops unless you have a lot of free space. I figure about three times the GB of the original DV for editing, processing and converting.
But welcome to our forums.
other than a couple special panasonic models that included software to capture over usb, without a firewire port your only choice is to send the tape out to a video service if you want to get full resolution video.
If you could pick up a used desktop PC for cheap, that might be one way to go. PCI FireWire cards are cheap enough and DV doesn't take that much computer power to do basic edits. The camcorder I use now is AVCHD, and though it has HD over USB, my laptop would still struggle a lot to edit it. Really, a desktop PC is the best choice for working with camcorder video.
Capturing DV camcorder to laptop w/o firewire port
By fvisagie in forum Capturing and VCRReplies: 33Last Post: 17th May 2012, 14:14 -
Record to memory card via firewire port?
By poflynn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 3rd Aug 2011, 16:18 -
Connect my camera to my pc: Dead FireWire port
By DJSPYDER in forum Newbie / General discussionsReplies: 15Last Post: 6th May 2011, 12:19 -
How can I capture video with no firewire port?
By dickieb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 22nd Apr 2011, 17:05 -
FireWire port has died
By ZiGGY909 in forum Capturing and VCRReplies: 2Last Post: 1st Feb 2010, 08:33
