Hi,
I've got a couple of MKVs that I'm trying to watch on my PS3 via ps3mediaserver. They currently play without sound and I believe that's because the audio stream is MP3 rather than AC3 or AAC (they both play fine on my laptop). Therefore, I thought I'd use ffmpeg to change the audio stream to AC3. I thought this would do it:
However, that gives me an error:Code:ffmpeg -i input.mkv -vcodec copy -acodec ac3 output.mkv
I have no idea what the heck that means or whether I'm just making some noob mistake here. Can anyone offer any advice?Code:[matroska @ 0x9ca0a0]st:0 error, non monotone timestamps 200 >= 40
You could just try another tool like avidemux, under audio change too aac or ac3. But I think mp3 should work fine ps3mediaserver...
You're right - I'm an idiot. I was getting mixed up with another video that plays without sound.
These particular videos don't play at all (invalid data or some-such) so the video stream is likely the issue. Copying the video stream will just give me the same issue.
I tried re-encoding with Handbrake but the quality seemed to really suffer (despite using the same target size with a two-pass encoding). Oh well, at least I can watch them now.
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 18:57 -
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 16:50 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
wots best method to split MKV - change DTA to MP3 then remux..?
By snadge in forum Video ConversionReplies: 1Last Post: 3rd Jul 2009, 14:33 -
Any way to change audio in MKV file?
By Timmychuck in forum AudioReplies: 4Last Post: 18th May 2009, 03:22
