    Nov 2007
    Canada
    Playing this movie file-ac3 xvid on my old pc running Windows XP Sp3 with Divx or Real player is perfect,yet the same movie file palyed under Window 7 Home with a newer version of Divx Player and Real Player,the audio is missing:-
    "additional audio decoder needed to play this soundtrack-Dolby AC3 Audio"
    Is there anything I can do for the problem?
    Thanks for helping!
    Oct 2005
    666th portal
    AC3 ACM Codec
    extract the files from the zip and right click on the .inf click on install.
    then reboot.
    Nov 2007
    Canada
    Thank you
    I followed your instruction and this is what I got
    The inf file selected does not support this method of installation
    Oct 2005
    666th portal
    it's the standard way to install on windows. did you use the right version? x86 for 32 bit windows or x64 for 64 bit windows?
    Nov 2007
    Canada
    I did use the x64 version.I am attaching this from Winzip
    Which I rithtclicked the inf and leftclicked install as said
  6. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    From within the winzip window or did you extract all the files first as aedipuss instructed ?
    Because that is the error you will get when trying to install it from within the ZIP file instead of extracting it first....
    Use something good like MPCHC
    https://www.videohelp.com/tools?toolsearch=MPCHC&Submit=Search&convert=&s=&orderby=Name&hits=50
    Nov 2007
    Canada
    Thanks Noahtuck
    I tried it both ways.when I tried to install ,my screen only flickered once,the process never took place.
