I installed DG and AviSynth and installed the DGDecode.dll in the Avisynth plugins directory. However, when I try to run it with LoadPlugin in the AVS, it says "Can't open plugin", even though I had no typos and installed it in the Avisynth plugins folder. So I took out that line and just ran MPEG2Source("...\video.mpg") it said "There is no function MPEG2source".
If anybody can help, that would be amazing.
1) you can try installing MpegDecoder into AviSynth plugni directory.
-or-
2) Demux video.mpg using DGIndex 1.5.8 save project n demux video. (as per my best knowledge DGDecode can only decode .d2v indexed files)
then try this....
LoadPlugin("[PATH\DGDecode.dll").MPEG2Source("[PATH]\video.d2v")
(thanks to Gavino for correcting typo! Oooops!)
Hope these should work coz i never had a problem with either one.Last edited by Bonie81; 18th Jun 2011 at 19:40.
Perhaps it was just a typo, but there should be no dot (".") between the LoadPlugin call and MPEG2Source.
Normally you would write them on two separate lines (though it's not compulsory).
Although, if DGDecode.dll is in the Avisynth plugins folder, it should be loaded automatically without using LoadPlugin.
AviSynth - JDL_ApplyRange() & FadeIn() Compatibility Issue?
By Typhoon859 in forum Video ConversionReplies: 18Last Post: 4th May 2009, 19:29 -
Autogain Issue in AVISynth and VirtualDub
By Gramps in forum Video ConversionReplies: 4Last Post: 22nd Aug 2008, 07:48 -
Help With DGMPGDec
By OrlandoEastwood in forum Newbie / General discussionsReplies: 15Last Post: 13th Dec 2007, 19:40 -
DGMPGDec plugin for AVISynth doesn't read MPEG file's audio
By Mark001 in forum Video ConversionReplies: 11Last Post: 9th Jun 2007, 18:07 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 14:10
