Please tell me, which is the best software to join an AVI files.
Thank you.
I will assume you are talking about Xvid/Divx when you say "AVI" file.
Well, using the super secret ultimately hidden search function, (which is shown on almost every page/post in the forum, including your own post) gave me a plethora of results, out of hundreds, this one popped up near the top...
https://forum.videohelp.com/threads/292223-Join-or-Combine-2-AVI-files-with-no-quality-...light=join+avi
And "best" is a subjective term at best.....
What is best for one may not be best for another.....
Also the "avi's" being joined must have the same spec's.
EDIT:
But as redwudz said, AVIDemux is also my usual tool for such task's. -
Yup! I know ...
This is aproblem ... yesterday I tried to join 2 AVI file, which own differ bitrate. 1413kbps and 1434kbps.
So, accordance to the result that I have it provide 355kbps only.
Thank you for your recommendation.
how join video file (various format)?
By Shohag_ifas in forum EditingReplies: 2Last Post: 18th Dec 2010, 00:32 -
Need a .bat file to join avi files
By aat666 in forum Newbie / General discussionsReplies: 2Last Post: 7th Oct 2010, 06:46 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 03:50 -
How do I join JPG images to creat an AVI file
By forensic in forum EditingReplies: 9Last Post: 15th Mar 2008, 21:23 -
Need to join a avi and divx file, not sure how
By MattP2007 in forum Newbie / General discussionsReplies: 5Last Post: 25th May 2007, 10:24
