How often should I delete cookies? Does it help the web browser work faster if you do? I hate to have to put in password info all the time after I delete them.
I use AVG to delete my cookies. It seems to know which ones to delete. It has never deleted password cookies. (and that is a misnomer) Your passwords are not stored in cookies as far as I know.
Disable cookies globally. Then only enable cookies for the sites you trust that need them.
Just download Glary Utilities, free and really good application .... will also check the registry. You will more than likely find your computer runs faster after using it.
Cheers from downunder.
Cookies
By Jomapil in forum ComputerReplies: 4Last Post: 5th Jan 2011, 04:30 -
IE8 website cookies removed after each reboot
By Nintendo Fan in forum ComputerReplies: 13Last Post: 2nd Mar 2010, 21:48 -
Are cookies considered malware?
By alegator in forum ComputerReplies: 6Last Post: 8th Jul 2009, 16:24 -
Does VHelp make any use 2o7.net cookies?
By gll99 in forum ComputerReplies: 11Last Post: 28th Apr 2009, 05:09 -
IE internet history/cache/cookies eraser for ALL users?
By sdsumike619 in forum ComputerReplies: 6Last Post: 11th Oct 2008, 20:32
