    May 2009
    Hi
    I'm currently building a website that will include 45 second samples of songs from albums. I'm just wondering if theres some way to automate this as I have quite a lot of samples to create.
    My original files are lossless wma but i can convert them to most formats with dbpoweramp - output needs to be mp3 to be playable through a flash player.
    ffmpeg -i audio.wma -ss 00:00:00 -t 45 -acodec mp2 output.mp2
    You could then make batch file for it with a loop that goes through all your wma files.
    May 2009
    sorry to sound dumb but that bit of code means nothing to me
    i also made a typo - I meant mp3, sorry
    It's a command line application that is VERY useful for automated stuff.
    Usage:
    -Extract ffmpeg.exe to c:\ffmpeg for example
    - Open a command prompt (go Start->Run, type in "cmd.exe" and press enter)
    - Change to the folder where you unpacked the files you downloaded (for example: cd "C:\ffmpeg")
    - Run ffmpeg like in the examples you see, like:
    ffmpeg.exe -i <input file> <output file>
    Or maybe somone know some easy to use GUI/Frontend that has these features.
