  1. Hello all...Noob here and I didnt see this in the forum, sorry if it has been asked.
    How can I author a autoplay slideshow onto a DVD, but also embed jped files onto the same DVD.
    Basically its a DVD movie on any DVD plaing device, but if I put the Disc in a computer and open the DVD there will be a folder of images.
    I've been searching high and low....cant find the answer I am looking for. I know how to make a DVD and DATA disc, but its combining the two onto one Disc is what I need help on.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just create your slideshow DVD....have the program output(give you) a VIDEO_TS folder. Add that VIDEO_TS folder to ImgBurn FIRST...then add another folder called DATA with your pictures. ImgBurn will create a playable DVD that just happens to have an extra folder that can be opened on a computer.
  3. Thanks Hech...Im going to try that out when I get home.
  4. Had to do a little tweaking in my process, but it worked like a champ! Thanks again.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Yea there are one or two more steps in ImgBurn, but those apply every time you burn from a folder. Glad it worked out.
