HI All,
I am very new to video codecs and just trying to figure out what its all about
I compiled ffmpeg library, and made a small C++ program that can extract key frames and save them as images from the videos.
I also noted that distance between keyframes is not even (for most of the videos that I tried divx, xvid mpeg4...)
Distance can vary from 1 to up to 300 frames. As I understand its related to shots encoding, eg new keyframe is inserted only if its very different to previous frame.
(In order to save space)
This is my question: When I convert videos with ffmpeg through console, I can manually specify keyframe distance, default parameter -g and its set to 12.
Is there any way to encode video with FFmpeg so that keframe distance will be variable ? (rather than consistent 12 frames or any other static number)
9 years later i'm playing with ffmpeg encoding "compilant dvix home theater" files for i'm not sure yet which reason... but i'm stuck with that defalut -g 12 in there. i can override it by setting manual max keyframe to ...120... but now the keyfamres are every 120 seconds despite scene change. WTF. I change the library to x264 and boom, keyframes are normal, following scene changes... back to mpeg4 or libxvid, it gets back evil. What are we doing wrong? does that -12 flag is burnt into ffmpeg since decades and nobody figured out it would be great to remove it as those libs aren't much used these days?
Vide on commercial sites
By PowerFalcon in forum Video Streaming DownloadingReplies: 9Last Post: 10th Jun 2012, 10:12 -
Joing mkv files when they are not splitted at keyframes
By wateshadon in forum EditingReplies: 1Last Post: 11th Jul 2011, 13:01 -
FFMPEG Flags for FLV keyframes
By infinull in forum Video ConversionReplies: 0Last Post: 13th Apr 2010, 22:36 -
vide size
By maxone58 in forum DVD RippingReplies: 7Last Post: 28th Mar 2010, 23:01 -
Batch Converting of Varouous vide fromats to Flash flv with ffmpeg
By tempgp in forum ProgrammingReplies: 0Last Post: 7th Dec 2007, 15:58
