I have Realtex audio card. Windows XP But can't get the speakers to mute when I plug in headphones. Auidio card is old.
I have found lots of same problem on Google. But no help.
Muting the speakers when the headphones are plugged in is a function of the phone socket itself on the card. When the plug is inserted, it switches the signal to the phones and mutes the speaker output. You need a special jack for that.
But you might find a external switch box that would work for you. Or install a audio card that does have a switching socket.
Mute Audio Via AviSynth
By stevendm in forum EditingReplies: 5Last Post: 6th Jul 2010, 11:39 -
Does 7.1 audio limit the rear speakers and divert to the side speakers?
By yoda313 in forum AudioReplies: 0Last Post: 4th Oct 2009, 10:55 -
Best Headphones
By Nitro89 in forum Off topicReplies: 26Last Post: 11th Dec 2008, 18:37 -
Mute Mike
By romanticwarrior in forum ComputerReplies: 1Last Post: 29th Apr 2008, 11:13 -
Mute a part of the Audio
By Flowbax in forum AudioReplies: 3Last Post: 25th Jul 2007, 08:46
