I have some DivX movies that I want to write to XVCD. The source files are all NTSCFilm (23.976 fps) at 640x304 pixels.
I've made a bunch of VCDs (352x240) but now I want to try a higher resolution XVCD.
I tried an XVCD at the same resolution as the source, (640x304) but this appeared squashed downwards, and the right hand end of the image was off to the outside of the TV![]()
What is the highest resolution I can convert to for XVCD?
Is there any way to correctly determine the ratio of height to width that I should use?
I'd REALLY appreciate some help
Cheers
Buzzrick
I think you can go as high as you want, but remember that the height and width have to be multiples of 8.
I only dream in black & white...
MSN: paschendale@gmail.com
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 12:57 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 08:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 09:28 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
